![]() | Home > In Car Electronics > Steering Wheel Upgrade |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
The Right circular button is for the menu settings and will not work on a pre-facelift variant, when I fitted a facelift steering wheel and switch packs to my old pre-facelift apart from the paddle shift and heated wheel the only thing that would work with the rotary switches is the audio controls, I did have a spare L/H switch pack which I fitted the inner parts from to the right hand side so both rotary switches controlled the audio.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Cheers Col |
Hi Guy, when I did mine I fitted paddle shift, heated s/wheel also had ACC so bought completely new circuit boards for the switches from blackbox solutions and honestly can't remember if the original circuit boards are compatible with the pre-facelift wiring/connectors, or if you may need new boards as well. If you are not fitting a heated wheel and paddle shift can't think of anything else you may need, but it was a few years ago I did mine and can't really remember, but will rack my brains and see if I can think of any other bits needed, on bbs web site they did have quite a good explanation of the conversion which may help you.
I had mine fitted to my 2005 supercharged both sides of the round controler would do volume up and down the clockspring only needs to be changed if you are fitting a heated wheel if the 2 pin socket is not fitted to your own clock spring so as said if not fitting heated wheel you would only need the wheel and switch packs and the boards from black box solutions which as i seem to remember are dearer than the wheel cost |
Thanks Col/ Geoffsnook,
