![]() | Home > Faults & Fixes > Front passenger door wont lock |
03184 Member Since: 11 Jul 2018 Location: Alicante Posts: 63 ![]() ![]() ![]() |
Hi Ken, In same scenario as you but with driver door. I am addressing it this week and will let you know. From what Ive read so far is that it is quite common. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
This is a common problem. I have had this problem on two of my doors.
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 ![]() ![]() ![]() |
Thanks for the reply I'm going to remove the door panel later and see if anything has dropped off or snapped. Likewise I'll post any results cheers. |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 546 ![]() |
It’s not worth taking the door card off without having the replacement latch available.....inside the latch unit are tiny little motors similar in size to those on scalextrix cars...these wind and unwind the latches electronically...they will have failed....
Thank you for the information I will squire a new latch before taking off the trim. The latch design appears to be cheap and nasty.. thanks anyway cheers |
They are actually quite complex when you see them up close...
Thanks Farmer Chalk.. good advice.. cheers mate. |
Pm me if you have any difficulties when doing it and I will try to guide you through it....
markhals Member Since: 16 Dec 2018 Location: Milton Keynes Posts: 2 ![]() ![]() |
Just attempted to replace the door lock actuator on the rear driver side door of our 2011 RRS but the replacement part I got off ebay (which said it was compatible) only had one plug port and the original had two. Anyone know where to source a two plug alternator? Comparison pic below, original on the right:
Either Advanced factors or Island 4x4 but you need to quote to them your VIN number as there are different types for different ages... |
Thanks Farmer |
Wwonder Member Since: 08 May 2019 Location: London Posts: 13 ![]() ![]() ![]() |
Recently had the same problem myself with the driver's door. Had the latch mechanism replaced - £80 labour, £30 parts - problem solved. |
That's because the one on right is a keyless one and the one on the left isn't ![]() MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
HI everyone, well i've removed the passenger door trim, i'm trying to replace my door latch as explained, My car is a 2007 range rover sport, i've hit a brick wall, i lower the glass down 5 inch, to see the window lower edge through the door aperture, i have located the white nylon clamp which locks the glass in place, but i can't fathom out how to release this clamp from the glass, i've read that you have to prise apart this nylon clamp but i can't for the life of me, figure out how to do this, what tool do i use, how much force is involved to achieve success, im at the stage of asking an indie to do it, if anyone has any suggestions id be very grateful, ill give it one more try..
