![]() | Home > Technical > Cornering light 2011 range rover sport |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
On my 2010, you have to put the indicator on in addition to having the lights on. |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
Does the vehicle not have to be between a certain speed range for this to work. Current: 2010 RRS 3.6 TDV8 HSE
Anno43 Member Since: 12 Oct 2018 Location: None Posts: 27 ![]() |
I notice mine come on and off when cornering around my estate, turning into drive and sharp corners on country roads doing around 20 mph.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5144 ![]() ![]() ![]() |
They only work with dipped headlights, ignition on/engine running and car in Drive, will work with or without indicator going and deactivate above 25mph I think.
Mine are as Col said except mine work in reverse also (but work opposite, i.e. if I am in drive and turning right, the right lamp comes on, but if I leave the steering alone and put it in reverse, the left lamp comes on which makes sense) they also work at least 40mph as I have a fun corner near home that I like to throw it around at 2am. 2019 5.0 SC SVA (Current)
Are we talking about the Cornering lights or AFS "bendy lights" as thought they deactivated at around 45mph, as for cornering lamps mine certainly only work in drive.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5127 ![]() ![]() ![]() |
May need to be moving
Cornering lights will work with vehicle stationary provided transmission is in drive, or at least mine do.
Oliverx5 Member Since: 20 Sep 2019 Location: Malaga Posts: 2 ![]() ![]() ![]() |
Hi, I have a LHD RR supercharged 2009 facelift model, I’ve just exported the car to Spain and subsequently changed he whole head lamp due to the fact the ones on he car were UK Spec. The lights I have purchased are Valeo, the reference is almost identical but note I have the AFS warning light and the cornering light doesn’t work, I was wondering if I dismantled the old lamps and switched over the ballasts and all electric components will this fix the issue??
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
I'm sure someone will be along that might be able to confirm this, but is there not a setting that you can change in one of the menus that allows you to set the headlamps for either driving on the left or right rather than having to change the whole headlamp, or is it more to do with them being UK spec. |
Thank you for the reply, Unfortunately not as the previous owner had changed the lights and put UK spec Valeo ones |
drb1709 Member Since: 24 Aug 2019 Location: West Sussex Posts: 38 ![]() ![]() ![]() |
Mine come on with the indicators as long as the lights are on, but only up to a certain speed, and also when on the move dependiant on the position of the steering wheel.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
I have the Osram LEDFOG101 fitted (replaces OEM fog lights with daytime running lights, fog lights, and cornering lights and I highly recommend). So I get cornering from the headlamp as well as the fog lamp. Suffice it to say, I can see where I am going even if I cannot answer some of the questions on this thread. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
bradtarga34 Member Since: 19 Jan 2010 Location: Walton-on-Thames Posts: 147 ![]() |
It could simply be that the bulbs are blown, it happened on my MY10 and had the bulbs changed when in service and all working again tickety boo |
