Home > Maintenance & Modifications > Fitting side steps
Oldandconfused
Fitting side steps
The drivers side step on my 2010 L320 has gone mushy where I stand on it to get in the car. Flakes of rust have started to appear on the driveway so I suspect they are past it.
I have done a search and have seen recommendations for replacements Thumbs Up
Bearing in mind there are brackets etc already on the car, is it simply a case of reusing these and swapping out the actual steps or will the brackets be different and need replacing as well?
I have no idea if the steps fitted are genuine LR or aftermarket as they were on when I bought it.
Any insight from anyone who has done this is appreciated.
Post #585230 Mon Aug 12 2019 8:41am
DEVON
Swapped mine out a while ago , for the same reason as you
The brackets I found to be the exact same , so cleaned them up and left the original ones in place .
The new steps slid on and bolted up no problem Thumbs Up
Post #585233 Mon Aug 12 2019 9:19am
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
did the exact same also. Car set to full height, impact gun zipped the old bolts off. Cleaned up the brackets and fitted the new ones. Spray some WD40 or washing up liquid along the edge of the new runners when putting them on, to just help slide them into place.
Post #585238 Mon Aug 12 2019 10:02am
Brit Plumber
Keep the originals as the guage of steel used is thicker 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #585247 Mon Aug 12 2019 12:15pm
Oldandconfused
Thanks for that guys, seems like a plan Thumbs Up
Post #585263 Mon Aug 12 2019 7:21pm
knwatkins
Mine came from here: https://turborevs.org.uk/side-steps-runnin...sport.html
£99.99 with free delivery.
I noticed when I had the car up on ramps the other week, they were rusting underneath so probably worth coating in a bit of hammerite on the underside prior to fitting. Kev
Post #585267 Mon Aug 12 2019 8:51pm
Oldandconfused
Those were the ones I was looking at Kev. I take your point about protecting the underside.
Post #585272 Mon Aug 12 2019 10:13pm
