Home > Wheels & Tyres > Tyre Change / Vehicle Height?
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I'll be having 4 new tyres fitted soon including Hunter Alignment.
I was wondering if it matters what height the car is at (Access / Standard / High) during the change process?
If it does matter what level should I make sure the car is at?
As always the advice of you good people would be appreciated.
Thanks. Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #585196 Sun Aug 11 2019 12:36pm
knwatkins
Standard height, but make sure they put your vehicle into tight tolerance mode. I believe the Hunter machine will prompt the operator to do this. Kev
Post #585211 Sun Aug 11 2019 8:01pm
SRE
Spain
BJH1959 / Barrie.
So how about an update on your new life outside the UK, the good (weather etc Very Happy ) the bad (taxes etc Big Cry ) you get the gist Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #585229 Mon Aug 12 2019 8:36am
syl
In case I ever have to have this done unplanned (eg after a puncture), how does one put it into tight tolerance mode - or does it need a piece of special equipment (and do all tyre places have it)? RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #585231 Mon Aug 12 2019 8:43am
knwatkins
It's done with a diagnostics tool, for example the GAP IID tool.
I'm not sure how tyre places or garages do it. Maybe the Hunter machine connects up to the car directly and puts it in the correct mode but I cannot be sure. Kev
Post #585232 Mon Aug 12 2019 8:59am
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I usually just lock the car down into access mode as you would if you were in a multi storey car park, this just stops things extending when the wheels are off the ground. Obviously if this is wrong someone correct me please! Wouldn’t like to give bumb info.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #585235 Mon Aug 12 2019 9:40am
aaronjb
That would seem to be totally the wrong approach to me, Stu - since the geo changes (dramatically) between ride heights, camber notably, if you set the camber up at Access height then it should be completely wrong at Normal height?
More info here: https://www.rrsport.co.uk/forum/post391302.html#391302 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585243 Mon Aug 12 2019 11:19am
Stu
@ aaronjb, sorry I maybe wasn’t clear with what I meant. It was only for the tyre change I lock it down as it were!. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #585244 Mon Aug 12 2019 11:23am
aaronjb
Gotcha, that makes much more sense Thumbs Up although I thought the idea was to lock it in fully extended mode for tyre changes; no idea why, just what the tyre place insisted I do.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585250 Mon Aug 12 2019 12:41pm
Brit Plumber
If I jack my car from extended, my jack runs out of reach. If I jack from access it’s well within its travel limit however when I lower the jack, I can’t get it out as the cars stance has now changed and I have to raise the suspension to remove the jack. If your just changing the tyres there’s no need for tight tolerance mode unless you have the alignment done (which you are). When I enquired at my local Hunter place they said they charge extra for plugging into the diag port as it’s not done as standard so I did it myself on the IDD tool. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #585253 Mon Aug 12 2019 3:13pm
BJH1959
Thanks everyone for your thoughts and advice.
@SRE - Happy to talk more about the good life here in Portugal on PM. Not sure how many others would be interested. Laughing Barrie.
Post #585269 Mon Aug 12 2019 9:06pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Brit Plumber wrote:
If I jack my car from extended, my jack runs out of reach. If I jack from access it’s well within its travel limit however when I lower the jack, I can’t get it out as the cars stance has now changed and I have to raise the suspension to remove the jack..
Think I know what's on top of your wish list Embarassed Embarassed Mr. Green
Post #586159 Sat Aug 31 2019 9:08pm
Brit Plumber
Top of my wish list would be a 2 post lift.
Top of the wife’s wish list maybe an extended jack or one that works more than once a weekend!!! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #586244 Mon Sep 02 2019 3:54pm
aaronjb
I have a scissor lift that the Cobra is currently sitting on .. brilliant bit of kit.
Sadly the RRS won't fit in that garage length wise, and won't fit in the other garage height wise Laughing first world problems! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #586245 Mon Sep 02 2019 4:03pm
