Home > Maintenance & Modifications > Fitting a winch: Part 1 |
Looking good mate, your car must be in shock! 2012 5.0 SC AB
Sun Aug 04 2019 9:09am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Few comments on this thread - I guess the OCD types are all out licking the dirt from the hidden places of their RRSs having seen the insides of yours! 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 04 2019 1:57pm |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
I must say that you are losing the bumper , your winch mount is just that , so in a crash you have zero protection . I have fitted mine with Devon 4x4 hidden winch bumper , that includes a sturdy side to side bumper and two winching points https://www.devon4x4.com/d44-discovery-3-d...t-kit.html TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Sun Aug 04 2019 6:36pm |
2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Sun Aug 04 2019 8:39pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
Try taking the rear bumper off a road car and it looks like that as well though. At least with mud you can see where to clean. 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Mon Aug 05 2019 8:56am |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I think the radiator will receive the gentle attention of a pressure-washer. Sod the rest! |
Mon Aug 05 2019 10:33am |
Perhaps not "zero", but "not insignificantly reduced", hence letting my insurance know before starting the job. I will write a note in the technical log alerting drivers to the increased stopping distance and the need to leave more space behind the car in front. One of the reasons for having a fully discreet mount is so there isn't anything protruding that could injure pedestrians. |
Mon Aug 05 2019 12:12pm |
I´m pointing that both front corners are weakier , and of course softer for pediastrians , but in crash with another car or in a offroad event like sliding in mud against a tree you are going to have increased damage in your car. TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Mon Aug 05 2019 3:31pm |
Thanks. It has quite a few dings already. |
Mon Aug 05 2019 5:55pm |
The crash bar is in the front of the car stretching to the sides of the car as i remembered when i fitted mine and i'm pretty sure the whincn mount and the whinch was more than adequate yes either side was a bit weaker but they are called crash bars for a reason as they deform in a certain way whers as the whinch will not as they are solid |
Mon Aug 05 2019 8:16pm |
The lower bumper bar also acts to prevent a low bumpered vehicle from running under the RRS. Look at the height of some cars' bumpers and you could see many would go under the upper bumper. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 05 2019 9:22pm |
