Home > Maintenance & Modifications > Fitting a winch: Part 1
HughN
Wales
Terrafirma discreet winch mount + Terrafirma 12000 lb winch with wireless control + wiring extension kit.
Bumper off (wiring left under tension - bad boy. Embarassed ) and everything doused in PlusGas.
Valve block released from the driver's side of the bumper reinforcement beam:
Washer reservoir removed from passenger side of the bumper reinforcement beam.
Reinforcement beam removed and plastic trim cut out with a sabre-saw so that it was flush with the mounting points for the bumper reinforcement beam:
I cut off the 'tab' on the washer reservoir (in picture below):
M8 captive nuts drilled out to 10mm (and given a whack with cold-chisel if necessary).
There was no way they were going to be at the correct spacing just by luck, so I effected a simple Go/NoGo tool by fitting a couple of the bolts into the bracket that goes behind the reinforcement beam mounts. As long as these fitted in the holes, the spacing was "good enough for government work".
Holding the mount in place to fit it was a PITA. It is a two-man job but I was on my own and just about managed. One hand and a knee holding it in place (with a couple of bolts in the mounting holes). Another hand holding the bracket behind the mounting brackets that held the reinforcement beam and yet another hand tightening the bolt (no washers, though?)
As usual with this sort of jobs, there was that stomach-churning tinkle of fittings bouncing their way down to sit above the under-tray - several times Rolling Eyes .
The washer reservoir is secured onto a bracket on the winch mount. The winch is a snug fit and I found two 'gotchas' that nearly me out: the fittings for the fairlead need to go in before the winch; the winch is fixed by bolts that go into square nuts in the 'feet' of the winch - the winch has to be tilted to fit and these nuts drop out, so Blu-Tak saved the day.
I'm just waiting on Terrafirma advice on fitting the control box. It could be me, but I think the wires are too short.
Watch this space...
Post #584902 Sat Aug 03 2019 11:36am
Brit Plumber
Looking good mate, your car must be in shock! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584941 Sun Aug 04 2019 9:09am
Few comments on this thread - I guess the OCD types are all out licking the dirt from the hidden places of their RRSs having seen the insides of yours! Rolling with laughter Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #584951 Sun Aug 04 2019 1:57pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
I must say that you are losing the bumper Sad , your winch mount is just that , so in a crash you have zero protection . I have fitted mine with Devon 4x4 hidden winch bumper , that includes a sturdy side to side bumper and two winching points https://www.devon4x4.com/d44-discovery-3-d...t-kit.html TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #584956 Sun Aug 04 2019 6:36pm
Buckster
Rolling with laughter Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #584970 Sun Aug 04 2019 8:39pm
Duc750
Try taking the rear bumper off a road car and it looks like that as well though. At least with mud you can see where to clean. 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #584979 Mon Aug 05 2019 8:56am
HughN
Wales
I think the radiator will receive the gentle attention of a pressure-washer. Sod the rest!
Post #584983 Mon Aug 05 2019 10:33am
HughN
Wales
Perhaps not "zero", but "not insignificantly reduced", hence letting my insurance know before starting the job. I will write a note in the technical log alerting drivers to the increased stopping distance and the need to leave more space behind the car in front. One of the reasons for having a fully discreet mount is so there isn't anything protruding that could injure pedestrians.
Post #584985 Mon Aug 05 2019 12:12pm
rangemogger
I´m pointing that both front corners are weakier , and of course softer for pediastrians , but in crash with another car or in a offroad event like sliding in mud against a tree you are going to have increased damage in your car. TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #584990 Mon Aug 05 2019 3:31pm
HughN
Wales
Thanks. It has quite a few dings already.
Post #584993 Mon Aug 05 2019 5:55pm
geoffsnook
The crash bar is in the front of the car stretching to the sides of the car as i remembered when i fitted mine and i'm pretty sure the whincn mount and the whinch was more than adequate yes either side was a bit weaker but they are called crash bars for a reason as they deform in a certain way whers as the whinch will not as they are solid Whistle
Post #584998 Mon Aug 05 2019 8:16pm
The lower bumper bar also acts to prevent a low bumpered vehicle from running under the RRS. Look at the height of some cars' bumpers and you could see many would go under the upper bumper. 2012 SDV6 - it's missing a couple of cylinders
Post #585000 Mon Aug 05 2019 9:22pm
