Home > Maintenance & Modifications > Rear dynamic response (ACE) bar replacement costs |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Budget around £13-1400, including fitting and replacing rear pipework |
Thu Aug 01 2019 5:04pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
You can buy the bar OEM which is about half the price of the same bar with LR stickers on it from an LR dealership. That helps get you to D_M's figure. LR charge £1300 or so just for the bar if you go to them...!
Thu Aug 01 2019 7:05pm |
Bruster400 Member Since: 12 Jun 2019 Location: Manchester Posts: 15 |
Thanks guys!!
Fri Aug 02 2019 12:50pm |
hmmmmm another quick question if you don't mind......
Fri Aug 02 2019 1:21pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
I know it's a bit of a trek from Manchester but for a Land Rover independent specialist try K Motors in Leyland. I've had pretty good service from them for a while now & their labour rates are about half the main dealers.
Fri Sep 06 2019 11:01am |
Just to update: Had this done last week for £1220 all in. Not the sort of bill you expect at <50k miles but it's a hell of a lot better than the other quotes I got!! Very happy with the garage - found through this forum too! For info: 6hrs labour for this job and they said they were able to do it without lifting the body which I'd been told couldn't be done....
Mon Sep 09 2019 11:38am |
Rear pipes too, or only the bar? |
Mon Sep 09 2019 12:06pm |
Sorry Disco_Mikey - I missed your question.
Tue Oct 08 2019 8:17pm |
