![]() | Home > Maintenance & Modifications > Brakes squeaking |
Did you fit the anti-squeal shims when you fitted your new pads?
russ1@me.com Member Since: 09 Nov 2018 Location: Cambridge Posts: 4 ![]() ![]() |
The pads didn’t come with any shims but I did use copper slip... rear side it worse than the off side.....cheers for the help. |
Actually, looking back at the pictures when I did mine, I don't think the pads on these vehicles have anti-squeal shims which would explain why you didn't get any! Sorry for the mis-information |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Check with the dealer if there is a TSB. When I had the same problem on my SC, the dealer said there was a TSB. It’s one thing they actually fixed on the car. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
The only thing that shut mine up, albeit a RRS1 S/C was EBC Redstuff pads not cheap but worth it to shut it up.
Sorry what is tsb? |
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 ![]() ![]() ![]() |
TSB - Technical Service Bulletin.
My front brakes squeak like an old style london taxi. But they do some job stopping this fat b*stard of a car in a hurry when required... |
https://www.rrsport.co.uk/forum/topic44976...+squealing
