![]() | Home > In Car Electronics > GPS memory fail |
Markymark Member Since: 24 Jul 2019 Location: Gloucester Posts: 16 ![]() ![]() ![]() |
I will look into this with Land Rover. Sounds expensive one way or another |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1902 ![]() ![]() |
Have a look at these posts: https://www.rrsport.co.uk/forum/search.php...rch_time=0 2023 P440e SE Dynamic on order -cancelled
Well done, there is no way a GPS antennae would be vertical on the glass, it is trying to see the satellites and would be on the roof.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
So is the car 2013 late L320 RRS1 or a early 2013 L494 RRS2? because if it's a L320 the power cable and coax lead to the rear spoiler will be the reversing camera.
col,its a late L320.it looks like someone has played about with it and fitted what my mate calls a 'T' antenna in the spoiler casing ????(i've no idea either )but LR should sort it next week. |
Is the car a HSE or SE as I don't think all SE's had navigation fitted and perhaps someone has retro fitted it, not sure but could be a possibly, as strange why roof antenna would be missing, unless of course it has previously packed up.
Col ,it's a hse black edition in Orkney Gray metallic. It's got TV and everything! |
Really strange, should have dual view if black edition as well, hopefully fit new aerial and will be back in business little fiddly to replace aerial but the headlining does flex enough without dropping it to far, unless you have hands the size of a shovel |
***UPDATE***
Right then,got car back from or yesterday, still not got a fully working sat nav.
That’s as per TECHNICAL BULLETIN LTB00642v3 mentioned on page 1. Second hand IAMs are £100 to £200 for the 12/13 MY but a MY14 to 16 should work.
