Home > Technical > Idle |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Mine has done the same and I think it’’s the Air con. It was 36 C when it happened.
Thu Jul 25 2019 3:10pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
yeah mine has been doing it.
Thu Jul 25 2019 3:43pm |
Mines the same and returns to normal when I turn the the ac off. 2012 5.0 SC AB
Thu Jul 25 2019 5:56pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
I’m a bit doubtful that the a/c accounted for it because I never turn the a/c off yet the idle returned to normal after restarting a hot engine.
Thu Jul 25 2019 11:29pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
My S/C seems to do that and fluctuates at times, just put it down to Air Con and ambient air temp high. Normal idle is less than 900 though, but being petrol may be different.
Fri Jul 26 2019 3:08am |
Mine doesn’t normally do it with ac on but when it did it the other day I turned it off to check and it returned to normal idle. So with no fault found I turned it back on again. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Jul 26 2019 9:09am |
to get the required pressure in the a/c system (due to high demand), it will increase idle |
Fri Jul 26 2019 11:31am |
