![]() | Home > Technical > Idle |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227
Mine has done the same and I think it’’s the Air con. It was 36 C when it happened.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
yeah mine has been doing it.
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Mines the same and returns to normal when I turn the the ac off. 2019 5.0 SC SVA (Current)
| LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336
I’m a bit doubtful that the a/c accounted for it because I never turn the a/c off yet the idle returned to normal after restarting a hot engine.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
My S/C seems to do that and fluctuates at times, just put it down to Air Con and ambient air temp high. Normal idle is less than 900 though, but being petrol may be different.
Mine doesn’t normally do it with ac on but when it did it the other day I turned it off to check and it returned to normal idle. So with no fault found I turned it back on again. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
to get the required pressure in the a/c system (due to high demand), it will increase idle |
| All times are GMT |
