Home > Technical > Mystery connector 2011 Sport |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
tyre pressure monitoring receiver I would think |
Wed Jul 24 2019 6:08pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Yeah, definitely TPMS aerial/antenna should be clipped to wheel arch liner, but wouldn't worry about it as the system on a RRS1 is pretty crap anyway.
Wed Jul 24 2019 10:03pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Yes, that's the antenna for the TPMS that communicates with the pressure sensor in the wheel. Kev
Wed Jul 24 2019 10:05pm |
You will see 2 small holes in a oblong shaped depression in the front wheel are liner, that’s where it fits. Check the other side and you should have plastic Riverts in there. Check the rear of the rear liners for the same on the rear. If you only have holes, I suspect someone’s tried to retro fit and gave up. If there all there, it’s dropped out or someone left it off for some reason. 2012 5.0 SC AB
Thu Jul 25 2019 6:01pm |
MM4747 Member Since: 22 Sep 2014 Location: Javea/Xabia Posts: 14 |
Thanks guys.
Thu Jul 25 2019 7:32pm |
Look for 2 holes (screw rivers installed in mine).
Thu Jul 25 2019 8:35pm |
Might have had the wheel arch liner removed before and the never refitted the antenna when refitting the liner, not unknown for dealers to leave thing off or disconnected. Cheers Col |
Thu Jul 25 2019 9:32pm |
Unless it’s the bill!
Thu Jul 25 2019 9:35pm |
Very True.
Thu Jul 25 2019 9:41pm |
