Home > Technical > Mystery connector 2011 Sport
MM4747
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Removed headlight cluster to replace Xenon bulb and found this wired up part lying unused underneath the headlight.
Any ideas anyone?
Very strange!! RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #584399 Wed Jul 24 2019 4:30pm
tyre pressure monitoring receiver I would think
Post #584403 Wed Jul 24 2019 6:08pm
Yeah, definitely TPMS aerial/antenna should be clipped to wheel arch liner, but wouldn't worry about it as the system on a RRS1 is pretty crap anyway.
Post #584414 Wed Jul 24 2019 10:03pm
knwatkins
Yes, that's the antenna for the TPMS that communicates with the pressure sensor in the wheel. Kev
Post #584415 Wed Jul 24 2019 10:05pm
Brit Plumber
You will see 2 small holes in a oblong shaped depression in the front wheel are liner, that’s where it fits. Check the other side and you should have plastic Riverts in there. Check the rear of the rear liners for the same on the rear. If you only have holes, I suspect someone’s tried to retro fit and gave up. If there all there, it’s dropped out or someone left it off for some reason. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584456 Thu Jul 25 2019 6:01pm
MM4747
Thanks guys.
The TPM system came as standard on my vehicle.
I'll have a look and see if the original securing location is still usable.
Otherwise I'll leave it where it is. It has given me warning signals before.
Can't figure out why anyone would have moved it.
Mechanics sometimes work in mysterious ways! RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #584464 Thu Jul 25 2019 7:32pm
Brit Plumber
Look for 2 holes (screw rivers installed in mine).
Post #584468 Thu Jul 25 2019 8:35pm
MM4747 wrote:
Thanks guys.
Might have had the wheel arch liner removed before and the never refitted the antenna when refitting the liner, not unknown for dealers to leave thing off or disconnected. Smile
Post #584471 Thu Jul 25 2019 9:32pm
Brit Plumber
Unless it’s the bill!
Never known them miss things off that!!!. 2019 5.0 SC SVA (Current)
Post #584474 Thu Jul 25 2019 9:35pm
Rolling with laughter Very True.
Post #584475 Thu Jul 25 2019 9:41pm
