![]() | Home > Technical > Tdv8 egr blanking |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Call Alive Tuning or Bell Auto Services for definitive answer but my understanding is you cannot blank a tdv8....keep your receipt |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420
Someone posted a while back having had his TDV8 EGR's successfully blanked by a company in Bristol, working out cheaper than replacing the EGR's. The company are apparently very experienced at doing this.
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422
Yes it can be done But can't be reversed 61 AB 5.0 supercharged rocket
Bodsy can do it for you 61 AB 5.0 supercharged rocket
I stand corrected |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322
I also read on here that's it's not recommend for the tdv8, but the person saying that didn't give any more info on why not. The guy who had them replaced did say that his fuel consumption had improved a lot too |
| S16ARV Member Since: 01 May 2017 Location: Dudley Posts: 4
Hi thanks for the replys. I've had the egr's mapped out now and I've just fitted the blanking plates. The car runs much better now and no lights on the dash. I have been told that the butterfly valves need removing now though but can't see how the butterflys come out. Has anyone else done this or will I be ok leaving them in? |
| Past91rrs09 Member Since: 05 May 2017 Location: Kent Posts: 9
S16 ARV , did anyone get back to you about the butterfly on a tdv8? As I'm also trying to find out, seem to find a lot about the tdv6 but not the tdv8 |
You need to snip or cut out the butterfly valves. Remove the unit and do it off the car is easier and less risk of bits of plastic floating in the engine!
| PaulMason Member Since: 15 Jun 2016 Location: Bucks Posts: 3
Why ds the butterfly need removing...and anyone have a photo of it ? |
| Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298
I have mine blanked on MY 08 TDV8 Without any problems |
So Ive fitted my blanking plates and mapped out the EGR's, I haven't removed the butterfly's as I'm not convinced they need to be. So far less smoke and spool up seems a little faster, but that's all I could say. Took about 45minutes to swap out. |
| MikeTDV8 Member Since: 07 Apr 2019 Location: Belgium Posts: 5
I’ve had the EGR’s blanked including a software adjustment on my MY 2008 5 months and 20.000 km’s ago, the car runs great.
| All times are GMT |
