| RRSPORT.CO.UK | ||
|  | Home > Technical > Tdv8 egr blanking |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | Call Alive Tuning or Bell Auto Services for definitive answer but my understanding is you cannot blank a tdv8....keep your receipt   | ||
|  Thu May 04 2017 1:11pm |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420    | Someone posted a while back having had his TDV8 EGR's successfully blanked by a company in Bristol, working out cheaper than replacing the EGR's. The company are apparently very experienced at doing this.
|  Thu May 04 2017 3:26pm |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | Yes it can be done But can't be  reversed 61 AB 5.0 supercharged rocket
|  Thu May 04 2017 5:28pm |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | Bodsy can do it for you 61 AB 5.0 supercharged rocket
|  Thu May 04 2017 5:30pm |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | I stand corrected   | ||
|  Fri May 05 2017 11:17am |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322      | I also read on here that's it's not recommend for the tdv8, but the person saying that didn't give any more info on why not. The guy who had them replaced did say that his fuel consumption had improved a lot too | ||
|  Fri May 05 2017 1:31pm |
| S16ARV Member Since: 01 May 2017 Location: Dudley Posts: 4    | Hi thanks for the replys. I've had the egr's mapped out now and I've just fitted the blanking plates. The car runs much better now and no lights on the dash. I have been told that the butterfly valves need removing now though but can't see how the butterflys come out. Has anyone else done this or will I be ok leaving them in? | ||
|  Mon May 08 2017 3:15pm |
| Past91rrs09 Member Since: 05 May 2017 Location: Kent Posts: 9      | S16 ARV , did anyone get back to you about the butterfly on a tdv8? As I'm also trying to find out, seem to find a lot about the tdv6 but not the tdv8 | ||
|  Tue Aug 01 2017 8:38pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | You need to snip or cut out the butterfly valves. Remove the unit and do it off the car is easier and less risk of bits of plastic floating in the engine!
|  Wed Aug 02 2017 8:55am |
| PaulMason Member Since: 15 Jun 2016 Location: Bucks Posts: 3    | Why ds the butterfly need removing...and anyone have a photo of it ? | ||
|  Mon Jun 03 2019 5:08pm |
| Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298      |
 I have mine blanked on MY 08 TDV8 Without any problems  | ||
|  Mon Jun 03 2019 6:31pm |
| PaulMason Member Since: 15 Jun 2016 Location: Bucks Posts: 3    | So Ive fitted my blanking plates and mapped out the EGR's, I haven't removed the butterfly's as I'm not convinced they need to be. So far less smoke and spool up seems a little faster, but that's all I could say. Took about 45minutes to swap out. | ||
|  Tue Jun 04 2019 3:26pm |
| MikeTDV8 Member Since: 07 Apr 2019 Location: Belgium Posts: 5      | I’ve had the EGR’s blanked including a software adjustment on my MY 2008 5 months and 20.000 km’s ago, the car runs great.
|  Mon Jul 22 2019 2:54pm |
| Posting Rules
