Home > General > 2008 Headlight |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
Several different one's depending on whether you have AFS, Cornering Lamps etc. should be a part number on yellow tag on top of lamp unit.
Sun Jul 07 2019 10:42am |
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 |
Hi Col
Sun Jul 07 2019 11:21am |
Rasher 007 Member Since: 12 Jan 2016 Location: Ashford kent Posts: 13 |
Hi fella, I had a light not upping and downing and bought a second hand one that looked the same as there are differences when you look at the lens and bulb arrangement. The sticker had a different number but I plugged it in and it worked with no issues at all. I’m sure if you were worried you could simply change the ecu on the bottom of the headlamp unit for your old one and all will be fine. Really easy job to be honest. Just look closely when buying to get the right one.mine is a 2007 tdv8 hse If a hammer won't fix it.... It's electrical!! |
Sun Jul 07 2019 12:22pm |
What is the number you have?
Sun Jul 07 2019 12:51pm |
Hi matey
Sun Jul 07 2019 12:52pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Sounds very dodgy to me. If the ball is loose I’d say the self levelling and direction motors are kaput. If so then changing the ECU wouldn’t help. But I don’t think it would hurt to try it. Robin
Sun Jul 07 2019 4:13pm |
