Home > In Car Electronics > Navigation arrival time
Wayneclarke
Just had my steering wheel swapped over so the battery was disconnected, once powered back up I noticed that the arrival time did not show.... any ideas of how to get it back???
Post #583584 Fri Jul 05 2019 5:17pm
Wayneclarke
sorry for the picture being sideways, ive tried removing the nav disc but no luck also tried changing the time again no luck.
Post #583592 Fri Jul 05 2019 8:41pm
scarey
arrival time works on previous speed/time taken etc so when you disconnected the battery everything was reset....
you'll find that after a few journeys the estimate time should come back..
Post #583600 Fri Jul 05 2019 9:24pm
Wayneclarke
Wow really ok well I will give it some time then, fingers crossed it's a silly thing really but something I miss having there
Post #583601 Fri Jul 05 2019 9:26pm
Wayneclarke
well been driving around for a few days now and still no change Sad
Post #583782 Wed Jul 10 2019 8:36pm
syl
Remembered hearing this before not too long ago.
https://www.rrsport.co.uk/forum/topic53805.html
Hope there’s something helpful in the thread linked there. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #583806 Thu Jul 11 2019 8:26am
Wayneclarke
Yeah I've messaged Him already to see if he had any luck but he said no joy so far.....
Post #583808 Thu Jul 11 2019 9:01am
Pego
Hi, I origally posted the same issue, I was told that it would come back ove time but it is still missing on mine.
Post #585949 Wed Aug 28 2019 10:34am
Wayneclarke
Yeah mine is still missing too, seems nobody has found why it does it and how to get it back.
Post #586071 Fri Aug 30 2019 9:15am
fly260
Italy 2006 Range Rover Sport TDV6 HSE Java Black
HI,
Have same issue on my one and found it's most surely related to last April GPS rollover.
https://www.us-cert.gov/sites/default/file...S_2019.pdf
If Sat Nav cannot get GPS time no ETA calculation is possible, you could just set to TIme To Arrival in general setting.
I found some info about other Denso sat nav here:
https://desk.zoho.com/portal/infotainment/...ite-signal
but they do not apply to RRS as it seems not possible to set time in our diag mode... I'm afraid our satnav need a firmware upgrade.
Anyone has so updates?
Post #586961 Sat Sep 14 2019 5:50pm
Pego
Hi again
Little update on sat nav arrival time
It's back, and all working fine,
Think maybe if you use the nav more often it may come back sooner.
Cheers for the help
Post #587070 Mon Sep 16 2019 5:47pm
