![]() | Home > Maintenance & Modifications > LED Light Bar |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
Pufftmw, just wondering which LEDs you're using for your main beam? I've been thinking about swapping out my current ones for either Xenons or LEDs.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Main beam is not Xenon, only dipped is. I just found the most powerful LEDs that would fit on eBay. If you do a search on here, there's a thread all about LEDs on which there should be a link. |
Thanks for the quick reply, Evilbay here I come |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
The main beam should be xenon if you have xenon dip - the non-xenon lamp is called a "fill in" lamp by LR that only comes on with main beam to help fill the pattern. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
In the end i went for a cheap bar that had fittings that can be positioned at any point in a track machined into the housing; the majority of others have fixings at the end which reduces options for mounting locations.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 421 ![]() ![]() ![]() |
I just bought a pair of PIAA RF18 light bars (driving beam) - amazing light output. They are built like the proverbial brick s*****e (2.1kg each).
Going from full-beam and LED lightbar (off-road, obviously |
Can't you use them on road legally in the UK. |
When I had a "course" run by an Essex police driving instructor for my club, one of the questions was additional lights (130W Cibies |
^^^ My photons are better than your photons. |
