![]() | Home > Maintenance & Modifications > LED Light Bar |
Can never have too much light |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 413 ![]() ![]() ![]() |
I am about to install a pair of Hella 350mm pencil beam light bars on both sides of the number plate.
Bigger picture
How do I make the image bigger? |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1906 ![]() ![]() |
2023 P440e SE Dynamic on order -cancelled
http://www.myhellalights.com/index.php/pro...t-bar-350/ 2023 P440e SE Dynamic on order -cancelled
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Very nice - but not cheap.
Wiring can run down the windscreen pillar trim as my loom does for my roof rack spotlights if they go on the roof |
Ace. I didn't know that was just trim. |
The other thing with these is you get what you pay for, these cheap lightbars and spotlights rarely last very long before the leds fail or they fill with water!! Better to buy from a well known company and you know it will last and be as bright as the company claim it is |
Yep. Good point. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9102 ![]() ![]() ![]() |
2008 TDV8 - it was a labour of love and is much missed |
I'm going to start off with a cheap 32" one fitted to the bumper: it may not be as effective as a 50" one fitted to the roof but the wiring is less complicated and the relay can be put in parallel with that for the driving lights and, therefore, under the control of the pukka switch on the dash; mounting it on the roof is more complicated and noisy.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Hey Hugh
