Home > General > Hot Spot Charging Point |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
I had a feeling they did , but could be wrong on that. Added this to mine so could charge phone shut in the glovebox out of sight, also fitted rocker switch so could make permanent live if required.
Wed Jun 12 2019 11:37pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
That's a neat little mod Col Kev
Thu Jun 13 2019 6:02am |
The answer to the question of whether the rear socket remains live is that it depends on model year - in 2010 the rear sockets in my FFRR were powered up with the ignition off, but we’re not for my 2011 and 2014 Evoques and the 2015 RRS but the 2007MY RRS and the RRS before that the sockets stayed live. I had to have a bespoke software enhancement to the BMS done to my first Evoque to allow me to use a solar powered trickle charger when the car was flattening it’s battery if not used for a week or longer. Since then I have got round the trickle charging issue by utilising the jump start posts under the bonnet and connecting my solar charger to those, but that isn’t much use for USB charging. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 13 2019 3:47pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 467 |
I guess its really a case of plug it in and see what happens..
Thu Jun 13 2019 7:26pm |
My 2012 (and all 2012 RRS) powers down as it is directly fed from the head unit which shuts down the media system after 5 minutes or something like that.
Thu Jun 13 2019 8:47pm |
This is what I’ve got in mine.
Thu Jun 13 2019 9:00pm |
This is the USB I was thinking about..
Thu Jun 13 2019 10:48pm |
Yes it will charge fine, but on a 12MY it will switch off after the ignition is off. That’s where I have my USB stick connected. 2012 5.0 SC AB
Thu Jun 13 2019 11:21pm |
In theory it will use its own battery and just top itself up when the car is running,
Thu Jun 13 2019 11:30pm |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 |
I had a hot sport similar to yours, I don't use mine as a Daily driver therefore it kept turning off when the battery ran out and my journeys were not long enough to charge it back up again.
Fri Jun 14 2019 9:26am |
I just use the app 'Hotspotstarter' on my phone and it starts and stops my hotspot when my phone connects to the Bluetooth in the vehicle Kev
Fri Jun 14 2019 12:50pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Just wow
Sat Jun 15 2019 9:53am |
