![]() | Home > Maintenance & Modifications > Indicator and Wiper Stalks Upgrade |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
They look so much more modern and a real bargin.....well done on both the idea and purchase price! |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
would this mod work on a 2007 ? the connectors look very similiar |
excellent - thanks Andy |
Reno Member Since: 12 Oct 2023 Location: loughborough Posts: 7 ![]() ![]() ![]() |
they look great, is it a steering wheel off job or just remove the cowling top and bottom? |
Just remove the cowling. No need to remove the wheel. Kev
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 432 ![]() ![]() |
Thanks all for flagging these. Just bought a pair on eBay for £35 posted. They’ll smarten up the interior a bit. |
Stalks arrived today and simple to fit. 2 x small Torx screws in the underside of the cowling and then just pull the top cowl off and the bottom one will drop down. Each stalk is held in by 2 x small Philips head screws. Once undone, pull the main block of each stalk off the mounting bracket.The main wash/wipe stalk is a little fiddly to get out, but do-able. Then each stalk has a connector which will need unclipping.
