Home > Maintenance & Modifications > Indicator and Wiper Stalks Upgrade
knwatkins
It's something minor, but I've always thought that the indicator and wiper stalks in my MY2010 looked a bit naff so I decided to upgrade them to some newer ones. These ones actually came from a D4 and I won them on eBay for £16.99 which I thought was a bargain.
Not a bad little mod I think...
Before:
After:
 Kev
Post #581303 Fri May 24 2019 9:55pm
skid1963
Are they a direct plug and play swap out??? 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged - Gone
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #581305 Fri May 24 2019 10:45pm
knwatkins
Yes, straight swap. 5 minutes to fit. Kev
Post #581312 Fri May 24 2019 11:34pm
Lucky you. Didn’t think you got Ebay bargains anymore.
Post #581314 Fri May 24 2019 11:41pm
knwatkins
I think it was luck to be honest Andy. I've seen these going for a lot more since. Kev
Post #581328 Sat May 25 2019 10:22am
Stevepd
That’s really smart Thumbs Up
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #581339 Sat May 25 2019 6:10pm
Brit Plumber
They are the same as the RRS 12MY and are the same as Disco 4. They are also similar to Evoque, Disco Sport, Freelander etc but they have the lights, fogs etc on the left stall. They also have an additional setting on the right stalk for Intermittent rear wipe which I’ve been toying with the idea of trying as it’s one feature I’d like as I do get fed up with looking out of the rear and then having to select rear wipe when I can’t see. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581367 Sun May 26 2019 10:36am
knwatkins
The Evoque stalks won't fit mate. They have different connectors....
 Kev
Post #581368 Sun May 26 2019 10:51am
knwatkins
 Kev
Post #581369 Sun May 26 2019 10:53am
Brit Plumber
That’s a Censored , I hadn’t realised the fittings were different. I really thought the intermittent wipe would be handy. 2019 5.0 SC SVA (Current)
Post #581372 Sun May 26 2019 2:37pm
my old RRS has intermittant rear wiper. (I think it can be changed via IID to constant)
I can even adjust the rear int. delay by using the adjuster on the stalk (as I have rain sensing front)
Post #581373 Sun May 26 2019 2:47pm
Brit Plumber
How do you set/change the delay on the rear int setting? Mine is the 12MY but it is on or off with no int setting. 2019 5.0 SC SVA (Current)
Post #581374 Sun May 26 2019 2:50pm
so the first thing you need to do is plug the IID in and edit the CCF to set rear as intermittant.
The thumb wheel on the switch (marked MAX) adjust the rear delay (as I have rain sensing front)
Post #581375 Sun May 26 2019 3:11pm
Brit Plumber
Thanks, I’ve also got rain sensing on mine but the thumb knob sets the time for the front wipe. Do you lose that functionality when you change the CCF? The manual mentions a CCF edit for drip wipe and says the rear wipe changes with vehicle speed but nothing else. I’ll have to have a look and see. 2019 5.0 SC SVA (Current)
Post #581376 Sun May 26 2019 3:38pm
Dunno.
Mine was like that.
I think I did see options in Ccf
Post #581377 Sun May 26 2019 4:19pm
