![]() | Home > Technical > Locked out! **update** |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Help!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
If you have tow electrics you could power car up thru white socket
No tow bar! ☹️ |
How does that work? Would it be ok on RR? |
Your issue may be getting to the pos cable.
Just had an after thought, if you can, you could remove the cable off the starter and that way it’s isolated. 2019 5.0 SC SVA (Current)
AA just been. Air bladders in top of door. Pumped out and fishing tackle to unlock internal handle. Deadlocked!😭😭😭 |
no issue connecting direct to the starter.
Decided to have another look yesterday after need to move car off drive for work being done on house. Fiddled with lock again and eventually it opened! Put battery back and moved it. This morning, went to move it back, started it, raised suspension from access height but front raised and before the rear could follow, warning came on dash 'front passenger door open' so checked door and it was closed! So now, I have a car that looks like it's doing a Whèely!
Open and close the door a few times, also leave it open for 10 minutes, just to see if it may release a sticky switch. 2019 5.0 SC SVA (Current)
switch is in the latch |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 929 ![]() ![]() |
Disconnect the battery & leave it for a while. Everything should reset back to default settings. |
MikeTDV8 Member Since: 07 Apr 2019 Location: Belgium Posts: 5 ![]() ![]() ![]() |
Recently my car locked up while the key was in the ignition, by using small airbags the car was opened by the friendly folks of the Dutch ANWB. |
