Home > Technical > Locked out! **update**
GARYF123
Help!
My 2007 sport had a flat battery. Had to take lock cover from passenger door and manually open it. On shutting door, noticed it wouldn't latch! On further investigation, realised latch had dropped inside door panel! 2 screws on drive floor ( no idea where third one is!) took door card off then realised that I could manage to get latch in position and secure with screws without getting behind door card!
Put battery on charge and locked door manually, job done.
Went to replace battery and cannot get in through passenger door manually. Key turns but door will not unlock! Is this cause door card is off but can't see why.
However, anybody got any ideas how can get in my car without breaking windows?!!!
Post #580465 Tue May 07 2019 10:45pm
If you have tow electrics you could power car up thru white socket
To allow unlock of car.
-3
+4
Post #580475 Wed May 08 2019 5:54am
GARYF123
No tow bar! ☹️
Post #580477 Wed May 08 2019 7:08am
Brit Plumber
Had a similar issue with a friends Audi a while back. Had to connect a spare battery via jump leads to the pos on the starter motor and neg to chassis. Then unlocked on the fob. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580479 Wed May 08 2019 7:37am
GARYF123
How does that work? Would it be ok on RR?
Post #580480 Wed May 08 2019 7:47am
Brit Plumber
Your issue may be getting to the pos cable.
I haven’t got my wiring diagrams handy but I’d imagine the RRS is no different to normal. The car positive is connected direct to the car battery so it’s almost like attaching jumpers direct to it. The starter won’t run unless it’s knackered as it needs an ignition live to the solenoid to move the pinion into line with the ring and then the motor would run. So no ignition, no starter run.
Hopefully one of the gurus will chip in and agree or disagree. 2019 5.0 SC SVA (Current)
Post #580481 Wed May 08 2019 7:56am
Brit Plumber
Just had an after thought, if you can, you could remove the cable off the starter and that way it’s isolated. 2019 5.0 SC SVA (Current)
Post #580483 Wed May 08 2019 8:04am
GARYF123
AA just been. Air bladders in top of door. Pumped out and fishing tackle to unlock internal handle. Deadlocked!😭😭😭
Post #580485 Wed May 08 2019 9:20am
Brit Plumber
Censored !
If you run out of options, try the above as you’ve nothing to lose by trying. 2019 5.0 SC SVA (Current)
Post #580505 Wed May 08 2019 12:26pm
no issue connecting direct to the starter.
pain if the metal under tray is fitted.
Post #580507 Wed May 08 2019 12:57pm
GARYF123
Decided to have another look yesterday after need to move car off drive for work being done on house. Fiddled with lock again and eventually it opened! Put battery back and moved it. This morning, went to move it back, started it, raised suspension from access height but front raised and before the rear could follow, warning came on dash 'front passenger door open' so checked door and it was closed! So now, I have a car that looks like it's doing a Whèely!
I guess it a sensor or switch somewhere in door mechanism? Anybody know where to squirt my switch cleaner?
Post #580898 Thu May 16 2019 8:30am
Brit Plumber
Open and close the door a few times, also leave it open for 10 minutes, just to see if it may release a sticky switch. 2019 5.0 SC SVA (Current)
Post #580900 Thu May 16 2019 8:37am
switch is in the latch
Post #580903 Thu May 16 2019 12:06pm
Lindab
Disconnect the battery & leave it for a while. Everything should reset back to default settings.
Post #580912 Thu May 16 2019 1:50pm
MikeTDV8
Belgium 2008 Range Rover Sport TDV8 HSE Lux Alaska White
Recently my car locked up while the key was in the ignition, by using small airbags the car was opened by the friendly folks of the Dutch ANWB.
Post #584310 Mon Jul 22 2019 4:00pm
