![]() | Home > General > Suspension issue with codes. Electrical or compressor? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
yes you could use that bulb.
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 ![]() ![]() ![]() |
Ok I done that mate.
that sounds good that the compressor makes a noise.
Ok. My impatience kicked in and I drove to Halfords to get a fuse!
Pipe leaking by compressor ?
I’ve done a bit more reading about the recent code, I didn’t realise the compressor was a wear item. I’m nearly at 120k miles now so even if it’s not the fault throwing the code it’s likely due a change anyway. Also I plan to sell the car in the next 6 months as I’ve had it over 6 years, it will be a nice thing for the next owner to see it’s been replaced regardless.
Hitachi are the original make. If you can get one of them that is fine. Or Dunlop
Ok this now got strange.
I am not completely surprised this happened.
Really? I’m very surprised
Has the yellow dash light been on for weeks? |
Yes. I ignored it as it still seemed to work ok going up
Drove it today and within 5 minutes the yellow light come back and usual dash warnings. It was always too good to be true.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
Slow filling is pointing to the compressor needing to be replaced. 2012 SDV6 - it's missing a couple of cylinders
