![]() | Home > General > Suspension issue with codes. Electrical or compressor? |
u codes are lost comms and can be ignores normally but check wireing connecters where they rub under arches and the like search on here and sister site disco 3 there are a few thread's about wires chaffing in and around the wheel arch |
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 ![]() ![]() ![]() |
Thanks. I’ll take a look under the car tomorrow.
i have heard of problems front nearside and offside rear try the rear first as there's no cover there but someone will come along with more idea's and knowledge |
Cheers. Yeah hopefully someone will give me some pointers who’s had the same problem. I done a search but couldn’t find anything relevant.
Anyone? Some help would really be appreciated
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
The problem is that the codes are incomplete. Presumably a generic reader was used. There are three entries for C1A27, 3 entries for U0132. By the way, you can download a free copy of the workshop manual which is invaluable. Search for a member on here called naks. There a link in his signature block to a download.
Thanks for that. My scanner is The Icarsoft 930 for Land Rover. It’s under £100 so I guess you get what you pay for.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5041 ![]() ![]() ![]() |
If you remove the relay you can bridge the 2 large contacts and see if the Comp runs.
Thanks Andy
May as well power compressor directly on the thick wires.
Thanks Andy. I’ll try and get that tested tomorrow and report back.
I just watched this vid.
Same place.
Don’t use the factory jack on these. They are very dangerous. |
