Home > In Car Electronics > Problem playing MP3s on memory stick (L494)
Three-Six Charlie
Help needed with an irritating issue playing MP3s via a memory stick
The Fat 32 formatted USB stick I'm using worked perfectly well in my Jaguar XFR, so should be Land Rover friendly too. All the older tracks that were already on the memory stick work fine in the Sport, but some newer MP3 tracks I've put on won't play, though they're the same format as the rest (these play fine when I plug the memory stick into my PC, so it's not a corrupt file problem).
When I select the track to play I get an error message stating 'File or Folder not available'. When I push the 'Help' option I get a screen saying 'Is the track a playable format (It's an MP3, so the answer must be 'yes'); 'Are the tracks protected in any way?' (If they are, I can't see it in the track properties, as all are ticked 'allow'); and thirdly, 'Is the device damaged?' (I very much doubt it as all the other tracks play)
Post #579323 Sat Apr 20 2019 3:22pm
samd
Could it be different bit rate?
Post #579326 Sat Apr 20 2019 3:48pm
jimbg
How did you create the newer one?
The MP3 format has developed over the years and you are probably using a subset that the Sport does not support. 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #579329 Sat Apr 20 2019 4:14pm
mrluke
Re: Problem playing MP3s on memory stick (L494)
Remember the mp3 is just the container, Many codecs are used with converting to mp3 .
I found that many "Downloaded" mp3s using some weird Chinese codec that didn't work in my Sport. I had to re-encode them with Lame encoder on Audacity and they all worked fine Wink
Give that ago.
Mines a 2012 so possibly the same Infotainment system as yours . My money will be on the encoder used !
Post #579332 Sat Apr 20 2019 4:58pm
Three-Six Charlie
Thanks all for the suggestions. It's possibly the converter I used. All the originals were converted from MP4 to MP3 using 'Ummy'. The latest were converted using 'Convertilla' as I'd run out of free conversions for 'Ummy' and I'm too mean to pay for software. Might try to find an alternative and see if that makes any difference.
Post #579346 Sat Apr 20 2019 9:07pm
See http://www.rrsport.co.uk/forum/topic50824-15.html
I also couldn't play any of my mp3s until I saw this thread and followed the advice to concert the files using the Lame codec.
now all my music plays fine. Thumbs Up --
Post #579353 Sun Apr 21 2019 7:46am
Three-Six Charlie
Problem solved-thanks all.
I used the free 'My MP4 to MP3 Converter' from Microsoft Store. It worked a treat.
Post #579355 Sun Apr 21 2019 9:08am
