![]() | Home > Maintenance & Modifications > Timing belt change on a low mileage vehicle Yes or No? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9149 ![]() ![]() ![]() |
I got mine done "early" because, as the garage said - if you don't do it now, you need to remember to get it done later because we might not remember.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479 ![]() ![]() |
I am heading for the same quandary on mine
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4529 ![]() ![]() ![]() |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
That is an issue has the 2 yr warranty runs out just after the 7yr service.I was under the impression the service manager thought he was talking to a company director when quoting £2186 but armed with the knowledge of their cambelt offer at under half that the Welder inside me popped out saying "How mucking Fuch mate!" Derby 4X4 have been recommended and are alot cheaper apparantly. |
If with a service excludes VAT then yes Mikey https://www.swanswaygarages.com/land-rover...s/cambelt/ |
If you use main dealers on older vehicles then you deserve to get your wallet emptied. The stamp in the book will never make the money back. Use a decent Indy FFS. Heck, it'd be cheaper to drive up to Jockshire, get Disco_Mikey to do it, spend the night in a hotel and drive home than use a main dealer in Englandshire. 2012 SDV6 - it's missing a couple of cylinders
BARRETTS LAND ROVER, ASHFORD are as below;
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
I am an advocate of whatever comes the soonest, ie time, on a low mileage car or mileage on a high mileage car. Rubber perishes with both age & use. Its not worth taking the risk of a breakage |
Not sure if I'm not charging enough, or if the dealers are charging too much |
You'd be able to almost half that quote at an Indy... |
Had mine done for (from memory) 850 all in with service included at a specialist indy. Bang on 7 years with mileage at around 84k. Although 60k is low mileage not worth the risk as the belts will eventually deteriorate.
Wow, these prices are crazy! |
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Just my 2p worth but I am with Lindab. Whatever comes first, age/mileage. Belts do snap. |
Some good points being made and I do agree that some of the main dealer pricing is ridiculous.
