Home > Technical > Rear suspension drop
The block with the compressor connects the pump to the reservoir and both to the front and rear blocks. It doesn't control any corners. 2012 SDV6 - it's missing a couple of cylinders
Post #578523 Sat Apr 06 2019 9:30pm
Jackiet
I have squirted soapy water on the rear pipe work, connections, valve block and even dropped the rubber gaiter on the strut but still couldn’t see any bubbles. The compressor is now off whilst I do the refurb, suspect it will a visit to the local indy when reassembled...
Post #578642 Mon Apr 08 2019 10:22pm
Jackiet
Update, the compressor has been rebuilt, all wheels measured from their centres to wheel arch’s and fuse 3 and 26 removed. Will see what happens over night ?
Post #578806 Thu Apr 11 2019 7:48pm
Jackiet
These were the heights from the wheel centre to the wheel arch when parked up last night with fuse 3 and 26 removed:- osf, osr and nsf were all 42cm from the wheel arch, nsr was 41cm.
This morning osf 39cm (-3cm) osr 35 cm (-7cm), nsf 36cm (-6cm) and nsr 30 cm (-11cm) I wasn’t expecting movement in all corners, would a leaking nsr strut cause this movement?
Post #578835 Fri Apr 12 2019 12:52pm
I wonder if its the white stuff in the system, that is preventing the seals from working?
I guess you may as well replace the seals in the middle block.
If you have an air line you could blow out the pipe to the front.
AT least you know you have done all you can then
Post #578838 Fri Apr 12 2019 2:14pm
Jackiet
Hi
When I got the dryer open it had already been rebuilt at some stage as the desiccant was the after market beads etc so very little sign of white powder in there.
Post #578839 Fri Apr 12 2019 2:44pm
Jackiet
What effect should uncoupling the plug to the rear valve block have, would the valves default to closed ?
Post #578840 Fri Apr 12 2019 2:58pm
yeah they should default to closed.
in theory should be the same as fuse removal, worth a go though.
It will generate fault codes, removing the fuse may prevent this.
Post #578842 Fri Apr 12 2019 3:41pm
probably best to leave fuse 3 in. (anyone else reading).
The ecu uses this to know if the compressor is on or off. (checks relay/fuse ok)
Post #578843 Fri Apr 12 2019 3:46pm
Jackiet
I rebuilt the middle valve block last night, removed the fuses and unplugged the Rear valve block plug. This morning both rear wheels are still down, the osr tyre is level with the arch and the nsr is even worse. Looks like both struts, is there a way to test them ?
Post #578995 Mon Apr 15 2019 10:12am
The airbags are pretty robust and seldom leak. To have both leak is an amazingly unlucky coincidence. I'd still suspect the valve block or their Voss connectors. 2012 SDV6 - it's missing a couple of cylinders
Post #579006 Mon Apr 15 2019 11:33am
Note.
It is possible for air to leak out the valve electrical connector! (the 3 tiny valve seals are responcable for this).
Just to add another factor into your experement, when your removed the electrical connector it could be more prone to leakage.
Post #579007 Mon Apr 15 2019 12:05pm
Jackiet
Quick update, I have replaced the air tank (new), the rear valve block (new), rebuilt the middle and front valve blocks and the compressor/air dryer. The suspension still dropped so I took it into the local Indy who could only find a leak on the compressor, so today I have fitted a new compressor and 3 hours later it’s sinking again !
Time to give up ?
Post #580703 Sun May 12 2019 6:50pm
You could remove the 20A fuse from under the bonnet, and see what happens overnight. (i.e if it still sinks, or only one corner sinks)
Don't know if you did this to start with, but worth repeating with all the newly fitted parts
e.g
run engine and ensure normal high obtained.
turn off engine and remove fuse within a few minutes
measure between wheel center and arch lip on rear if you want to be scientific.
leave over night
inspect in the morning and remeasure where applicable
Post #580726 Mon May 13 2019 12:06pm
Jackiet
Just to update, I had the car into a LR specialist who found an air leak coming from the top nut thread on the n/s/r strut. This strut has now been replaced (although both rears already looked like new) and it seems to have cured the rear end problem at last.
However i have now realised that if the car is left parked for several days the whole car drops equally on all corners !
I have raised the suspension, removed all fuses/relay relating to the suspension and after a few days it appears it’s the front dropping now, next stop new front valve block!
Post #582050 Sat Jun 08 2019 10:30pm
