Home > Wheels & Tyres > Wheel bolts from 20" to 19" ?
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
hi i have standard 20" alloys from the 2005 sport
i am looking to get a set of these 19" alloys:
https://i.ebayimg.com/images/g/tlAAAOSw9zdcZUXJ/s-l500.jpg
i believe they will fit but i am not sure if my current bolts will be suitable?
hopefully somebody can help but happy to provide more info
thanks
chris
Post #576498 Wed Mar 06 2019 10:36am
airc909
so here is a sport my age with those wheels fitted so guessing they must by same stud pattern
https://i174.photobucket.com/albums/w96/911wise/DSC_0001.jpg
just need to know about the bolts...
Post #576499 Wed Mar 06 2019 10:39am
Tyrefitter
All sports are the same stud pattern 5x120 but the offset can be different depending on wheels. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #576500 Wed Mar 06 2019 10:54am
airc909
any idea on the bolts mate
Post #576501 Wed Mar 06 2019 11:03am
Tyrefitter
Should be the same,,sometimes aftermarket alloys have different nuts. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #576502 Wed Mar 06 2019 11:10am
airc909
ok so these are definitely 5x120 so that is ok
they are off a Vogue
apparently if my bolts are flat on the back they will fit but if they are coned they wont
mine are flat (assuming the back is the bit you see when you look at the wheels lol)
Post #576504 Wed Mar 06 2019 11:26am
riverblanche
as you have said, think there a FFRR wheel not a standard RRS wheel
you have not mentioned tyre size yet Question
istr FFRR are different to RRS (may be in a good way Whistle ) RRS are 255/50/19
and if your buying wheels with tyres on I would be going for a decent brand and check the DOT code for the age of them Shocked
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #576507 Wed Mar 06 2019 1:28pm
If the wheels are off a Fullfat Vouge prior to 2004 you will need the Fullfat wheel nuts as the shank of the nut is a different diameter to the Sport and the Sport one will not go through the rim if I remember correctly.
Post #576591 Thu Mar 07 2019 4:26am
airc909
Col - thanks mate. Thumbs Up
Post #576600 Thu Mar 07 2019 10:24am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
airc909,
Just came across this earlier post. I have some 2004 20" Vogue wheels that don't fit my RRS. with Brembo brakes.
I know about the wheel nuts being different. Just interested to see how you ended up. Did you get them and any other problems?
PS On my RRS Sport it has Conical shaped shanks on the nuts but the wheels are for flat ones. Found you can use the Conical ones. They have to have a thin extra washer to make sure the shank length is the same. But CAN'T put a flat end into a Conical wheel 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #589356 Sun Oct 27 2019 10:13pm
As Sport wheels are spigot mounted I think you may find the flat washer on genuine sport wheel nut assists clamping force the washer also tightens against the wheel face, the nut then tightens against the steel washer which in turn prevents damage to the aluminium wheel by the nut turning against it when torqued up, not sure it has anything to do with the length of the shank, the same as the taper on the end of the shank is just that a taper and makes it easier to align the stud, wheel and nut.
Post #589362 Mon Oct 28 2019 4:56am
