![]() | Home > Wheels & Tyres > Wheel bolts from 20" to 19" ? |
airc909 Member Since: 28 May 2018 Location: Coventry Posts: 112 ![]() ![]() ![]() |
hi i have standard 20" alloys from the 2005 sport
so here is a sport my age with those wheels fitted so guessing they must by same stud pattern
any idea on the bolts mate |
Should be the same,,sometimes aftermarket alloys have different nuts. Andy.
ok so these are definitely 5x120 so that is ok
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
If the wheels are off a Fullfat Vouge prior to 2004 you will need the Fullfat wheel nuts as the shank of the nut is a different diameter to the Sport and the Sport one will not go through the rim if I remember correctly.
Col - thanks mate. |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
airc909,
As Sport wheels are spigot mounted I think you may find the flat washer on genuine sport wheel nut assists clamping force the washer also tightens against the wheel face, the nut then tightens against the steel washer which in turn prevents damage to the aluminium wheel by the nut turning against it when torqued up, not sure it has anything to do with the length of the shank, the same as the taper on the end of the shank is just that a taper and makes it easier to align the stud, wheel and nut.
