Home > General > Engine Intake Decarb
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I finally got around to trying some Liqui Moly Diesel Engine Intake Decarb.
I removed the upper intercooler pipes and started the engine - what a racket. Engine still works with no mass flow.
Next with the help of the wife I sprayed it into the intake in 2-3 second bursts (she kept the revs at 2000rpm). I thought the engine was going to shack itself to bits. But gradually it settled down to a smooth idle (but loud) with each spray.
The outcome is improved throttle response and driveability.
Well worth the effort.
Post #573808 Fri Jan 25 2019 12:33pm
Lindab
Used to do this with Redex about 50 years ago (not Range Rover Laughing ) Pour it into inlet manifold, loads of white smoke from exhaust. Looked impressive. Idle speed used to increase after it so its debatable if it made much difference, but you persuaded yourself you had loads more power
Pal of mine fitted an electric fuel pump & reservoir of Redex connected into the inlet manifold in his Cooper S & used to flick it on when at the lights. The car behind vanished in a dense cloud of white smoke, much to the annoyance of the owner Rolling with laughter Things you got up to when young. Happy days Very Happy Very Happy Very Happy
Post #573810 Fri Jan 25 2019 1:06pm
Meiang
My recurring "performance reduced" problem has not appeared since carrying out the procedure.
Post #574130 Wed Jan 30 2019 4:23pm
