| RRSPORT.CO.UK | ||
|  | Home > Technical > Webasto FBH |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      |
 Thanks I spotted this last night and contacted him via PM on here but haven't heard anything yet? I also noticed he does Bell remaps I thought he did or used to work for Alive? Where did you get the iid tool? Would it be worth buying just to do these bits or has it other uses? How much was it? Cheers Laurence. | ||
|  Sun Dec 30 2018 5:50pm |
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150    | The GAP II tool is available from Dan at Duckworth parts.
|  Sun Dec 30 2018 5:59pm |
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189    | The IID tool is well worth the money, it allows you to fault find and change settings, I have already enabled the towing settings and the puddle lights in the mirrors.
|  Mon Dec 31 2018 12:00am |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      | Thanks I’ll contact Dan   | ||
|  Mon Dec 31 2018 8:32am |
 Which one should I get there seem to be different ones available - BT, Tool & Pro?? Cheers Laurence. | ||
|  Mon Dec 31 2018 9:19pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | BT £425 ish
|  Mon Dec 31 2018 9:32pm |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227      | Get the BT (Bluetooth) it works with your phone, tablet and is tied to your vin number for fixes or changes to the CCF.
|  Mon Dec 31 2018 9:35pm |
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189    | Def the BT one (unless you want to spend a fortune and then charge others to do “stuff” to their cars) 2016 Black SDV8 Autobiography
|  Mon Dec 31 2018 9:44pm |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      | I cant get any reply from Bodsy so I'm going to muddle through this myself is this the right kit?
|  Fri Jan 04 2019 1:15am |
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166      | There is a group buy over on the disco3 forum for the iid tool, ran by Duckworth’s think you save about £10 over their Ebay item https://www.disco3.co.uk/forum/new-iid-group-buy-sign-161417.html
|  Fri Jan 04 2019 10:04am |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      | That sounds like a very good idea..  | ||
|  Fri Jan 04 2019 11:06am |
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166      | Mine was fitted behind the access panel in the boot on the right hand side. | ||
|  Fri Jan 04 2019 11:45am |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      | I'll have a look....  | ||
|  Fri Jan 04 2019 7:50pm |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649      | Is it in there?
|  Fri Jan 04 2019 8:42pm |
| Posting Rules
