![]() | Home > Technical > Webasto FBH |
| Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649
Thanks I spotted this last night and contacted him via PM on here but haven't heard anything yet? I also noticed he does Bell remaps I thought he did or used to work for Alive? Where did you get the iid tool? Would it be worth buying just to do these bits or has it other uses? How much was it? Cheers Laurence. |
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150
The GAP II tool is available from Dan at Duckworth parts.
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189
The IID tool is well worth the money, it allows you to fault find and change settings, I have already enabled the towing settings and the puddle lights in the mirrors.
Thanks I’ll contact Dan |
Which one should I get there seem to be different ones available - BT, Tool & Pro?? Cheers Laurence. |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
BT £425 ish
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227
Get the BT (Bluetooth) it works with your phone, tablet and is tied to your vin number for fixes or changes to the CCF.
Def the BT one (unless you want to spend a fortune and then charge others to do “stuff” to their cars) 2016 Black SDV8 Autobiography
I cant get any reply from Bodsy so I'm going to muddle through this myself is this the right kit?
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166
There is a group buy over on the disco3 forum for the iid tool, ran by Duckworth’s think you save about £10 over their Ebay item https://www.disco3.co.uk/forum/new-iid-group-buy-sign-161417.html
That sounds like a very good idea.. |
Mine was fitted behind the access panel in the boot on the right hand side. |
I'll have a look.... |
Is it in there?
| All times are GMT |
