Home > General > "Lazy" Seats
TubaPlayer
"Lazy" Seats
I seem to remember that on my 55 plate super charged there was an option for Lazy Seats or something similar that moved the seat back when the ignition was switched off, is there a similar option on a 2013 Black Edition?
Also can the seats be set to move to a preset position based on which key is used to unlock it? 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #568550 Thu Nov 08 2018 7:28pm
Should be a small rotary knob to left of steering wheel on steering column to turn function on and off, "lazy seat " function went out with the P38 I think you will find, you can't programme individual keys for seat/column position anymore either it's done on memory buttons in door panel.
Post #568557 Thu Nov 08 2018 9:10pm
geoffsnook
It's lazy entry on the early cars Thumbs Up
Post #568561 Thu Nov 08 2018 9:23pm
TubaPlayer
Thanks guys.
I def had it on my 2005 S/C, its a shame its not still there as my wife is about a foot shorter than me so I have to move the seat before I can get in. 2016 Black SDV8 Autobiography
Post #568563 Thu Nov 08 2018 9:41pm
Buckster
If you put the switch to auto on the column then it should move the seat when you hit the engine stop button. 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #568565 Thu Nov 08 2018 9:45pm
TubaPlayer
I'll check when HWMBO gets back, but i thought it was in the auto position. 2016 Black SDV8 Autobiography
Post #568566 Thu Nov 08 2018 9:54pm
Brit Plumber
The auto function on my car just moves the steering wheel but as I have mine set in the Park position anyway, it never moves. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #568568 Thu Nov 08 2018 10:11pm
Never use it as always switched off, but sure it moves column and seat when in auto on mine, can set column position initially with knob in either position though.
Post #568569 Thu Nov 08 2018 10:27pm
Cymruambyth
Wales
I might be missing something but why not just use the memory settings Thumbs Up Steve.
Post #568610 Fri Nov 09 2018 12:57pm
TubaPlayer
Generally it's not a problem using the memory button, the problem comes when it's raining and I have to wait for the seat to move so I can fit in whislt getting very wet!
And yes I have asked her to move the seat befor getting out but .......... 2016 Black SDV8 Autobiography
Post #568617 Fri Nov 09 2018 2:09pm
have you got a 2013 ? or both ?
I'm sure the 2005 can be configured to select a memory position when the unlock button is pressed.
The confusion is that there are 6 memories!
3 for one key
3 for other key!
I don't know if turning the CCF option of personalisation stops this stupidity!
Post #568620 Fri Nov 09 2018 2:29pm
TubaPlayer
I've only got the 2013.
I just remember the setting from the 2005 one. I remember the key memory being really good. 2016 Black SDV8 Autobiography
Post #568633 Fri Nov 09 2018 6:25pm
Maybe time to change your profile if you can
Post #568637 Fri Nov 09 2018 7:40pm
TubaPlayer
I will once I manage to actually see it in the day light to get a decent picture Laughing 2016 Black SDV8 Autobiography
Post #568642 Fri Nov 09 2018 9:42pm
There is the icon thing
Post #568646 Fri Nov 09 2018 10:37pm
