![]() | Home > General > "Lazy" Seats |
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189
I seem to remember that on my 55 plate super charged there was an option for Lazy Seats or something similar that moved the seat back when the ignition was switched off, is there a similar option on a 2013 Black Edition?
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
Should be a small rotary knob to left of steering wheel on steering column to turn function on and off, "lazy seat " function went out with the P38 I think you will find, you can't programme individual keys for seat/column position anymore either it's done on memory buttons in door panel.
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
It's lazy entry on the early cars |
Thanks guys.
I'll check when HWMBO gets back, but i thought it was in the auto position. 2016 Black SDV8 Autobiography
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
The auto function on my car just moves the steering wheel but as I have mine set in the Park position anyway, it never moves. 2019 5.0 SC SVA (Current)
Never use it as always switched off, but sure it moves column and seat when in auto on mine, can set column position initially with knob in either position though.
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
I might be missing something but why not just use the memory settings |
Generally it's not a problem using the memory button, the problem comes when it's raining and I have to wait for the seat to move so I can fit in whislt getting very wet!
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
have you got a 2013 ? or both ?
I've only got the 2013.
Maybe time to change your profile if you can
I will once I manage to actually see it in the day light to get a decent picture |
There is the icon thing |
