![]() | Home > Faults & Fixes > Parking brake fault help |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I'll say it before somebody else does, but if you have fitted it to a Jeep I think you fitted it to the wrong vehicle, which could explain why it doesn't work:lol:
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 475 ![]() ![]() |
I think your problem may be your driving a Jeep.. ===========================================
brendymcn Member Since: 24 Oct 2018 Location: Dublin Posts: 7 ![]() ![]() ![]() |
What you mean ?? |
This is Jeep |
This is the jeep |
No this is a Jeep. |
They are saying it’s a Range Rover and not a Jeep. My jeep is a real jeep at 77 years young.
Range Rover there a Jeep lol I am not sure if they do need calibrated there nothing on snap on computer to calibrate it .. That the last thing I was thinking does it need to be plugged into a factory computer |
Col, that’s not a jeep! This is a jeep. ![]() 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Have you read Bodsys bible? This should help.
I will try that bedding in the brakes it might put a bit of life into things .. Thanks for that |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Having recently had a EPB module fitted to my MY10 RRS, it does need to be re-calibrated. Your Snap-on tool may not be able to do that (mine was done at a local indi who had a bloke who does all the electrickery stuff for him). |
