Home > Faults & Fixes > Parking brake fault help
brendymcn
Ireland 2009 Range Rover Sport TDV6 HSE Orkney Grey
Hi my parking brake module stopped working think the plastic cogs wore out in the module .. ( lights all on on the dash and parking brake fault showing) I replaced the module with a new one it came new cables and all put it in the Jeep I can now put the handbrake on and off with the diagnosis computer .. I use a snap on computer by the way .. it will let me apply the handbrake on and off but as soon as I plug it out the lights flash on dash saying handbrake fault .. I thought next thing it was a faulty switch so I replaced the switch and still the same problem lights flashing and no handbrake 😒😒 ..Am lost as what to do next I think only other thing could be a wire broke going down but then again don’t think it would work with the computer.Also checked the fuse it seems ok . Anyone else have this problem can help me out please before I crack up ..
Post #567584 Wed Oct 24 2018 9:28pm
I'll say it before somebody else does, but if you have fitted it to a Jeep I think you fitted it to the wrong vehicle, which could explain why it doesn't work:lol:
Post #567586 Wed Oct 24 2018 9:32pm
Autobiography1969
I think your problem may be your driving a Jeep.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #567587 Wed Oct 24 2018 9:33pm
brendymcn
What you mean ??
Post #567589 Wed Oct 24 2018 9:44pm
brendymcn
This is Jeep
Post #567590 Wed Oct 24 2018 9:45pm
brendymcn
This is the jeep
Post #567591 Wed Oct 24 2018 9:46pm
No this is a Jeep. Thumbs Up Rolling with laughter
This is a Range Rover Sport
Post #567592 Wed Oct 24 2018 10:05pm
Brit Plumber
They are saying it’s a Range Rover and not a Jeep. My jeep is a real jeep at 77 years young.
Does the new handbrake module not need calibrating? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567594 Wed Oct 24 2018 10:09pm
brendymcn
Post #567595 Wed Oct 24 2018 10:11pm
brendymcn
Range Rover there a Jeep lol I am not sure if they do need calibrated there nothing on snap on computer to calibrate it .. That the last thing I was thinking does it need to be plugged into a factory computer
Post #567596 Wed Oct 24 2018 10:13pm
Brit Plumber
Col, that’s not a jeep! This is a jeep.
Post #567597 Wed Oct 24 2018 10:13pm
Brit Plumber
Have you read Bodsys bible? This should help.
https://www.disco3.co.uk/gallery/albums/us...ssPics.pdf 2019 5.0 SC SVA (Current)
Post #567598 Wed Oct 24 2018 10:30pm
brendymcn
I will try that bedding in the brakes it might put a bit of life into things .. Thanks for that
Post #567604 Wed Oct 24 2018 11:13pm
[/quote]
Nice One Thumbs Up
Post #567608 Thu Oct 25 2018 6:06am
Oldandconfused
Having recently had a EPB module fitted to my MY10 RRS, it does need to be re-calibrated. Your Snap-on tool may not be able to do that (mine was done at a local indi who had a bloke who does all the electrickery stuff for him).
Post #567612 Thu Oct 25 2018 9:58am
