![]() | Home > Technical > Oil Leak noticed - any help appreciated |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5066 ![]() ![]() ![]() |
looks like diff drain plug,
Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6 ![]() ![]() |
Hi
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 564 ![]() ![]() |
Thanks for the info scrumps - I get it now!
Have you had any work done recently? 2019 5.0 SC SVA (Current)
Serviced a few weeks ago.....
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Don't go overboard tightening it. If you're competent then you'll know how easily the steel thread will strip it's surroundings in that housing.
If there still oil dripping in the mornibg I’ll take it in this week.
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
The plug has lock tight on it when you buy it, you can see a trace of white on the thread in the picture. The torque setting is 28nm so if you have a low range torque wrench you could see if it’s tight enough. It doesn’t go all the way in some thread will still show when tight.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I don't know if it's just the angle of the photo, but it doesn't look square to the thread, almost as if it was cross-threaded. This could explain why it's tight but still leaking. Did you have the diff oil changed? |
Best to take it back if it’s just been a serviced |
Update:
