| RRSPORT.CO.UK | ||
|  | Home > Technical > Oil Leak noticed - any help appreciated |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | looks like diff drain plug,
|  Sat Sep 29 2018 3:50pm |
| Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6    | Hi
|  Sat Sep 29 2018 4:03pm |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586    | Hi,
|  Sat Sep 29 2018 4:25pm |
| Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6    | Thanks for the info scrumps - I get it now!
|  Sat Sep 29 2018 4:58pm |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | Have you had any work done recently? 2019 5.0 SC SVA (Current)
|  Sat Sep 29 2018 5:15pm |
| Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6    | Serviced a few weeks ago.....
|  Sat Sep 29 2018 8:18pm |
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150    | Don't go overboard tightening it. If you're competent then you'll know how easily the steel thread will strip it's surroundings in that housing.
|  Sat Sep 29 2018 8:21pm |
| Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6    | If there still oil dripping in the mornibg I’ll take it in this week.
|  Sat Sep 29 2018 8:42pm |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227      | The plug has lock tight on it when you buy it, you can see a trace of white on the thread in the picture. The torque setting is 28nm so if you have a low range torque wrench you could see if it’s tight enough. It doesn’t go all the way in some thread will still show when tight.
|  Sat Sep 29 2018 8:44pm |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | I don't know if it's just the angle of the photo, but it doesn't look square to the thread, almost as if it was cross-threaded. This could explain why it's tight but still leaking. Did you have the diff oil changed? | ||
|  Sat Sep 29 2018 8:49pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Best to take it back if it’s just been a serviced | ||
|  Sat Sep 29 2018 9:14pm |
| Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6    | Update:
|  Mon Oct 01 2018 2:59pm |
| Posting Rules
