Home > Technical > is this all battery related? hdc gearbox park brake
Page 3 of 3 <123
geoffsnook
Your battery is knackered buy a new one you will get there in the end anyhow Thumbs Up
Post #565079 Wed Sep 12 2018 4:26pm
W18ODY
cheers for replies lads, the surface charge is interesting this would probably be why it showed 12.6v all day then when connected to the car dropped to 10.4?
new battery is on the cards just wanting to make sure it is only the battery and i dont have a drain on the car as well, most my journeys are short as well so i think ill get a ctek charger as well. im also away for 2-3 weeks at a time so it will be neccesary then i think.
Post #565082 Wed Sep 12 2018 4:40pm
W18ODY
looking at betteries seems the enduroline and the exide are both common, anyone got a preference?
cheers.
Post #565084 Wed Sep 12 2018 5:01pm
geoffsnook
As long as its an agm and has a long guarantee Thumbs Up
Post #565087 Wed Sep 12 2018 6:07pm
Tim in Scotland
As well as AGM you should also consider a higher CCA battery if your car sits outside all winter, cold weather has less effect on high cold crank amps batteries when you are starting up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #565089 Wed Sep 12 2018 6:13pm
Doesn't need AGM. Standard battery is fine. Go for something 100Ah 900A.
Yuasa silver from Halfords gives a 5 year warranty. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #565104 Wed Sep 12 2018 11:34pm
W18ODY
cheers for the replies everyone!
ive read that it would be worthwhile getting an agm as i do a lot of short journeys, when reading up it seems a lot of the batteries are higher cca than what was fitted as standard so hopefully ill be alright these are the teo im looking at currently buth same price 4 years guarantee etc
https://www.tayna.co.uk/car-batteries/exide/ea1000/
https://www.tayna.co.uk/car-batteries/enduroline/019/
Post #565112 Thu Sep 13 2018 10:32am
Fairly sure the RRS diesel needs a 019 battery, although the little engine versions might be 017, not sure. 2012 SDV6 - it's missing a couple of cylinders
Post #565142 Thu Sep 13 2018 11:33pm
W18ODY
new battery arrived friday great service from tayna, so far so good! cheers for the help everyone!
Post #565270 Sun Sep 16 2018 2:06pm
Page 3 of 3 <123
