Home > Maintenance & Modifications > Flashing green hi light
Packard66
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Hi all I'm new here & this is my first post. I wonder if any one can help with my problem, and before anyone asks I have been to my Dr and has given me a cream for my other problem 😂.
Iv bought a 2007 sport tdv6 with a transfer box fault meaning the special program does not work. After a plug in check was told that transfer case ECU located behind battery was at fault, so I opened it up and could visibly see it has burnt out so cleaned all connections and replaced with a new one. Still not working but now green light on dash flashing hi also hi and low button flashing with warning saying "transmission range change not available".
So was told the transfer box actuator was seized which I have replaced ! Guess what still have the same message and problem. Iv attached some pics (none of me as I don't want to scare you) 😝 any help would be greatly appreciated xxx
Post #564458 Tue Sep 04 2018 11:46am
Disco_Mikey
New modules need programming and calibrating before normal operation can be resumed Thumbs Up
Post #564461 Tue Sep 04 2018 12:27pm
Brit Plumber
Have the fault codes been cleared? Have you tried a battery disconnect and reset?
Have you found why the ECU burnt out? Has water got in and caused it to blow? I just wonder what blew it in the first place and could your new one have blown because of the original fault. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564462 Tue Sep 04 2018 12:29pm
Packard66
Thank you will find someone to do this Thumbs Up
Post #564463 Tue Sep 04 2018 12:42pm
Packard66
I could see water damage so I suspect this was the cause, the new one is till ok have made sure water cant get in. did try the battery reset but to no avail Sad
Post #564465 Tue Sep 04 2018 12:45pm
