![]() | Home > Maintenance & Modifications > Flashing green hi light |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
New modules need programming and calibrating before normal operation can be resumed |
Have the fault codes been cleared? Have you tried a battery disconnect and reset?
Packard66 Member Since: 04 Sep 2018 Location: Croydon Posts: 5 ![]() ![]() ![]() |
Thank you will find someone to do this ![]() |
I could see water damage so I suspect this was the cause, the new one is till ok have made sure water cant get in. did try the battery reset but to no avail ![]() |
