![]() | Home > General (L494) > L949 buying advice |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Been a member for quite a few years and have gained lots of useful info and great advice, I currently own a 2011 Plate RRS, and I’m looking to purchase the newer model, preferably the later 2015 model onwards, with the newer engine.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
L494 air suspension has access mode which lowers the car when the doors open. My 17 SC is an HSE. It doesn’t have extended leather but the interior is fine, I wouldn’t reject a car based on HSE vs Autobiography but the must have for me is Dynamic pack. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
Eh? All RRS in the UK have air suspension, don't they? ![]() 2008 TDV8 - it was a labour of love and is much missed |
That has been given a red SPORT badge which would indicate HSE Dynamic but it's just a straight HSE. The lack of low range and Terrain Response 2 shows it doesn't even have the on-off road pack. So it's a base model. Maybe that's why it's cheaper than you expect. The difference between HSE and Autobiography is "a lot". As for your question about "must haves" - there are none. It's up to you what is important. Some will like big wheels and black bits, others won't. Some will want the upgraded hifi and adaptive cruise control, others won't. Some will want the off road tech, others won't. Me? I'd want off road bits, tow bar, small wheels, no shiny black bits, adaptive cruise control, heated wheel, timed climate. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I know your after white but if you should change your mind on colour their is this one
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1197 ![]() ![]() ![]() |
what mileage do you do?
Chips Member Since: 09 Nov 2017 Location: Shropshire Posts: 124 ![]() ![]() |
Did the 4cyl diesel come with steel springs or am I getting confused with the velar ? |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 310 ![]() ![]() |
J2D one of the first things you mention is the v6 crankshaft issue, what you need to remember is you must buy the car from an Lr approved used dealer as from people’s experiences on here if the crank breaks & it’s over 3 years old & you didn’t buy it from one of there dealers then they won’t cover it with the supposed good will gesture. If your not bothered about travelling & your quick to move on the ones that you like I’m sure you will pick up a good deal even from a Lr approved dealer. The price spread is huge on these even in the dealer network, around £10-12k from the cheapest to the most expensive usually with similar spec & mileage. Stratstone is usually the cheapest & they normally won’t discount screen prices even without a trade in. Another good tip is if your buying with a pcp & you have a lloyds or Halifax account you can get around 3.9% Apr from them but the car must cost £60k or less.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Sorry - I saw that the off road pack included air suspension, but that's only for the 4cyl. It comes as standard on the others. I think the old SE may have had coil suspension as well before it was dropped. RRS MY17 SDV6 AB
Velar, I think. I have a feeling that in some markets, RRS was/is available with coil springs (the D5 is too) but in the UK the RRS is air only. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
Wow, I'm surprised. Perhaps it didn't sell which is why it's no longer available. Why would anyone buy a coil sprung RRS? |
You’re right - it’s hard to see why someone would buy a new RRS with coil springs.
The older ones were converted because the air springs weren't as robust and reliable as the later systems are - they were known to fail, especially in hard off road conditions. There is the whole "you can't fix it with a big hammer and swearing" attitude at play too.
