![]() | Home > General > Alarm randomly goes off |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
The bonnet switch may LOOK ok but unless you test it you won`t really know. They`re not expensive to replace. I changed mine on the off chance that was the problem and it was. Steve. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 423 ![]() ![]() ![]() |
The bonnet switch on my car was the cause of the alarm going off randomly. I changed it and the problem has never returned. They are cheap to buy and easy to install. |
glennp123 Member Since: 04 Dec 2017 Location: n.ireland Posts: 36 ![]() ![]() ![]() |
Happened me at work one day, was rather embarrassing. |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 ![]() ![]() ![]() |
Ok, alarm went off today after 4 days of car not being used, still.no message on dash when it goes off, re set itself and never went off again, have linked out the bonnet switch to see if it stops this random issue, fingers crossed, thanks |
I never got a message for mine, but done the loop with wire on the bonnet sensor and that was it sorted, never done it again! |
Copilot Member Since: 06 Jan 2014 Location: Sussex Posts: 31 ![]() ![]() ![]() |
+1 for the bonnet switch as the likely culprit. This was exactly the case on mine about six weeks ago, and was a quick easy fix for the lads at my local indie (it was booked in for other stuff, before anyone mocks me for paying for such a small job!) |
