Home > General > Alarm randomly goes off
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Alarm randomly goes off, have looked at dash when alarm sounding, no message on dash ? No pattern to when it goes off, might be sat on drive for few hours or a day or so, no error codes etc showing on IIDTOOL,removed the suspect bonnet switch all looks good, think it might be the front passenger door switch as donโ€™t use this much and when I do seems alarm goes off a while later, how easy is it to remove this unit ? Door card etc removal ? Thanks ๐Ÿ‘๐Ÿป
Post #561485 Tue Jul 17 2018 8:34am
Cymruambyth
Wales
The bonnet switch may LOOK ok but unless you test it you won`t really know. They`re not expensive to replace. I changed mine on the off chance that was the problem and it was. Steve.
Post #561491 Tue Jul 17 2018 12:14pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
The bonnet switch on my car was the cause of the alarm going off randomly. I changed it and the problem has never returned. They are cheap to buy and easy to install.
Post #561772 Sun Jul 22 2018 7:35am
glennp123
United Kingdom 2007 Range Rover Sport TDV8 HSE Firenze Red
Happened me at work one day, was rather embarrassing. Confused ... it will be the bonnet switch which if standing at front of the car is at the left hand side hatch for the bonnet to catch onto. you can unplug it and make a loop with a bit of wire and put it in the end of the sensor plug which then completes the circuit and voila no more alarm going off.
hope this helps.
Post #561809 Sun Jul 22 2018 9:12pm
paul2415
Ok, alarm went off today after 4 days of car not being used, still.no message on dash when it goes off, re set itself and never went off again, have linked out the bonnet switch to see if it stops this random issue, fingers crossed, thanks
Post #562113 Fri Jul 27 2018 11:57am
glennp123
I never got a message for mine, but done the loop with wire on the bonnet sensor and that was it sorted, never done it again!
Post #562170 Fri Jul 27 2018 9:50pm
Copilot
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
+1 for the bonnet switch as the likely culprit. This was exactly the case on mine about six weeks ago, and was a quick easy fix for the lads at my local indie (it was booked in for other stuff, before anyone mocks me for paying for such a small job!)
Post #562328 Mon Jul 30 2018 9:40pm
