![]() | Home > General > Newbie advice please. 3.0 OR 3.6 diesel? |
PompeyDave Member Since: 08 Jul 2018 Location: Portsmouth Posts: 64 ![]() ![]() |
Sounds good but mine is already 8 years old. |
glennp123 Member Since: 04 Dec 2017 Location: n.ireland Posts: 36 ![]() ![]() ![]() |
As far as the 3/6TDv8 engine goes i love it... i had the turbos fail on me in March however.. cost £1800 to replace them.. but if it doesnt give me any other bother then its worth it.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8879 ![]() ![]() ![]() |
£1800 to replace both turbos seems amazingly cheap! 2012 SDV6 - it's missing a couple of cylinders
Yeah it was £970 for both recond turbos, then rest labour.. body off etc .. It def helps if it has been done a few times! |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
I just renewed with them, my online quote was £1370 with 30% parts contribution and £50 excess. Got it down to £700 with no contribution and £50 excess. Confirmed snapped crankshaft cover. Call them, they'll talk. Merc C220 estate Sport AMG Merc C220 estate Sport AMG 125 year edition Alfa GT Rover 76 V6 |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Ridiculous mate. Steve. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
High quality synthetic engine oil will certainly help, along with replacement of oil on time, or better still, more frequently than service regimes suggest. The problem with oil cooled turbos is that whilst oil is flowing when the engine is running, all is well. It’s when the engine is switched off and the oil in the turbo stops flowing that carbonising occurs, within the hottest parts of the turbo. After enough carbon has built up, oil flow is restricted and bearings become tight leading to turbo failure. Hence the well known practice of allowing a turbo to cool at tickover before switching off. Turbos get hotter under load, so removing the load whilst still having oil flowing through the turbo for a couple of minutes, helps to minimise oil carbonising within. My local indy has changed many 3.6 turbos and claims that most were due to lazy servicing. Either not done on time or using cheap oil and oil filters. |
I restore Lambretta scooters as a hobby, and the principle is very similar. The old adage of ‘buy cheap, buy twice’ is true in almost every case. |
