Home > Maintenance & Modifications > Bluetooth Factory Kit Install ( HHHEEELLPP )
Page 3 of 3 <123
Kirbs
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Hi Andy i have attached a picture of the offending plug that i can't seem to place with a corresponding plug on the car, this is the end plug on the harness kit. all other plugs are hooked up to the head unit, power supply, Nokia module and bluetooth module supplied with the kit.
perhaps I'm missing something and there may be a plug hidden in the dash somewhere but this is a female with the cam lock type of fitting and also seems to have on the back a clip to secure it to the body work.
hope this helps, I'm struggling to make sense of it, cheers
Post #561938 Tue Jul 24 2018 1:19pm
Which number are you having a problem with?
Is it one connector you have a problem with or two/pair?
Have you searched for Bluetooth with your phone ?
Post #561949 Tue Jul 24 2018 6:36pm
Kirbs
Hi image 157 plug B cheers
Post #561952 Tue Jul 24 2018 6:59pm
Kirbs
Hi Andy all the plugs are in and bluetooth not seen when searching.Its the cam lock plug that does not seem to be included in the comic strip instructions that i am having problems with locating its other half. its not plug b as i stated earlier but its the one above it in the picture 157. this is the end of the harness supplied.
any thoughts, cheers
Post #562255 Sun Jul 29 2018 12:00pm
removed.
Post #562256 Sun Jul 29 2018 12:12pm
Look at page 16 of the insptructions. The wiring diagram.
Do you think its might be the "base plate telephone" connector?
That wire would reach under the arm rest wouldn't it? Although the kits is meant to be bluetooth only? Crying or Very sad
So you have trying to follow the user instructions?
Turned ignition on.
Bluetooth enabled on your phone, and run a scan.
Something should appear. Ford?
Or maybe you are missing a module?
Post #562258 Sun Jul 29 2018 12:26pm
Kirbs
right so you think it is for a phone cradle is that what you mean? it would be long enough to reach
have looked for bluetooth but noting came up and still get the phoned not fitted message on the car display.
radio works ok and the steering wheel controls all respond ok.
i can take the laptop to the car and go through a few things or if your ok i can call you, cheers
really starting to pee me off now !
Post #562260 Sun Jul 29 2018 1:04pm
Kirbs
also the car has voice command fitted and a mic in the centre light so is there a module is should be looking for or do i install the second mic with the kit?
Post #562261 Sun Jul 29 2018 1:15pm
It wouldn't surprise me if you still get the "phoned not fitted message" even when working, as its a ford bolt on kit.
I'm afraid there its no good calling me. I have never kitted one of these kits so really can't answer your question.
Check you front cigar lighter still works (when you took the power from)
I assume you had the ignition on when you were searching for a bluetooth signal? It needs to be on I
pictures of the rear of the headuinit with connectors plugged in, may help.
Otherwise try and do some research on the internet
Post #562264 Sun Jul 29 2018 2:06pm
Kirbs
hi, just checked the colour codes on the harness and they match those on the wiring diagram in the fitting instructions as you mentioned for plugging into the base plate connector.
power is all present to the cigar lighter, radio works and steering wheel buttons work also.
yes ignition on when searching for bluetooth, will get you some pictures of the head unit plugs.
thanks for your help, cheers
Post #562272 Sun Jul 29 2018 4:44pm
Page 3 of 3 <123
