Home > Technical > Cool box/fridge
DEVON
Cool box/fridge
With the hot weather upon us I decided to have my air con re-gassed yesterday , and fit the cubby box fridge I bought 12 months ago Rolling Eyes
My question is .... Is the fridge supposed to switch off automatically after the ignition is turned off ?
If I don’t switch the little green light switch off , mine seems to run indefinitely ? And I’m wondering if I’ve done something wrong like I usually do Rolling with laughter
And would this not drain the battery ?
Thanks for any help/suggestions
Devon
Post #560375 Sun Jul 01 2018 11:03am
Mine certainly turn off with the ignition, although it is a facelift but I don't think that should make any difference.
Post #560376 Sun Jul 01 2018 11:16am
DEVON
Cheers Col
Im just concerned that if I forget to turn it off , I’ll return to the car with a flat battery ?
I don’t think I did anything wrong, the plug I eventually found was wrapped in some grey foam and only fits in one way
Maybe the fridge is faulty ??? But it is cold , and now full of Red Bull Thumbs Up
Post #560377 Sun Jul 01 2018 12:14pm
garrycol
Australia
Mine does not turn off with the ignition and yes it will drain the battery in about 18 hours if left on. Last month I parked the car at 8 in the evening and left a map light and the fridge on and the car would not start at 11 the next day. Battery still had enough power to unlock the car, light up the dash and do a slow turn on the starter but not enough to fire the car and after the first go - nothing.
The fridge does work well though.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #560378 Sun Jul 01 2018 1:04pm
DEVON
Thanks Garry
I’ll just have to remember to turn it off
It’s been running for the last 3 hours , but I have my ctek connected just in case. The fridge works really well . It’s a lot colder than I thought it would be , so all in all I’m really pleased with it Thumbs Up
Post #560379 Sun Jul 01 2018 1:22pm
Strange. My old 08MY TDV8 used to turn the cooler cubby off when the ignition was off as does my 2012 SDV6. I seem to remember they did change the design of the cooler because of this issue. 2012 SDV6 - it's missing a couple of cylinders
Post #560385 Sun Jul 01 2018 3:47pm
DEVON
Cheers RRSTDV8 Thumbs Up
Did they change the design so it stays on ??
I’m pretty sure the fridge I bought from the bay of fleas was from a MY10 , so maybe that’s why it doesn’t turn off with the ignition. But it does fit and works perfectly .
Devon
Post #560388 Sun Jul 01 2018 4:23pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
No problems on a 2012 sdv6 in terms of draining battery.
Post #560393 Sun Jul 01 2018 5:52pm
DEVON
Does that mean yours doesn’t turn off with the ignition Farther Jack ?
Post #560394 Sun Jul 01 2018 6:08pm
Cymruambyth
Wales
I`m sure my light is blue Neutral Steve.
Post #560395 Sun Jul 01 2018 6:24pm
DEVON
From what I have read on here Steve , some are blue and some green ?
I can’t find anything regarding if it should switch off with the ignition Thumbs Up
Post #560396 Sun Jul 01 2018 6:57pm
Father Jack
Sorry, probably should have been clearer. If I stop and switch off with it running it has never killed my battery. In fact a few times I have forgotten it was on until noticing the subtle noise it makes when you are stopped in traffic for example.
Post #560397 Sun Jul 01 2018 7:01pm
syl
I've just been out to mine (MY17), which has a factory fitted coolbox with a green light in the switch. It hasn't been used all day, the light is out (despite being switched on) and the cool box is at "room" temperature. On switching on the ignition, the green light illuminates. Mine is left permanently switched in the on position, with a couple of cans of diet coke and a couple of bottles of water in there, and I have never suffered from a flat battery even after leaving the car at the airport for a week whilst on holiday. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #560398 Sun Jul 01 2018 7:02pm
Scrumpy
This will probably confuse matters but mine has a blue light and I'm sure it does not switch off with the ignition but maybe some time after the ignition is switched off.
I haven't used it for a while as it's full of other bits but when I do I'll update this post. 2016 RRS SVR Estoril Blue
Post #560399 Sun Jul 01 2018 7:13pm
DEVON
Hmmm the mystery continues Laughing
Thanks to Farther Jack and Syl for there comments .
It seems like everyone’s work differently with different colored lights , typical Land Rover Rolling with laughter
I’ll keep an eye on it and see what happens. Its not a daily driver and I have a spare battery Thumbs Up
Post #560400 Sun Jul 01 2018 7:28pm
